Activity › Forums › Apple Final Cut Pro Legacy › Prores 4444 software down-converting
  • Prores 4444 software down-converting
    Posted by Nico Scott on July 27, 2012 at 12:00 am
    Hi All,
    I’m really looking for some info on workflows others find work best when down-converting Prores 4444 1080p footage/projects using software.
    I have a FCP7 project with the above settings, however the end target is actually PAL SD for broadcast. I know many people suggest working in a sequence that you will finish in, but everything I’ve been given for this job is 1920×1080 (graded footage, graphics, animation).
    I’ve tried a few test exports to PAL SD using FCP (QT conversion), Compressor with various settings, After Effects and also dragging the original sequence into a PAL SD sequence in FCP. These all seem to wield varying results, AE seemed to be the better option.
    In an Ideal world I’m sure a hardware conversion would be far better, but I don’t have this luxury. Could anyone suggest specific settings/software they feel would do the best job? Even additional software that I could get, if it’s not too pricey.
    Any feedback/comments greatly appreciated.
    Cheers,
    Nico
    Art Director says “What do you mean by title safe?”…Bangs head on wall.
    Nico Scott replied 14 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Eric Pautsch
    July 27, 2012 at 3:16 am
    Not sure if you have access to a PC but Ive been using a various of this workflow for several years and it beats or, at least, equals any hardware converter….and its all free
    Hardware conversions are mostly a tape to tape workflow anyway.
    https://bellunevideo.com/tutdetail.php?tutid=12
  • Nico Scott
    July 27, 2012 at 4:32 am
    Thanks for the info Eric. Unfortunately I don’t access to a PC, but I’m interested to check out this workflow for future reference.
  • Rafael Amador
    July 28, 2012 at 10:25 am
    The best software resizing tool for Mac is, by far, Apple´s SHAKE.
    If you can get it, don´t hessitate.
    rafael
    http://www.nagavideo.com
  • Nico Scott
    July 30, 2012 at 12:22 am
    Thanks Rafael,
    I’ll see if I can locate a copy somewhere…
    Out of interest does anyone use Motion for down conversion with good results?
  • Rafael Amador
    July 31, 2012 at 11:28 am
    [Nico Scott] “Out of interest does anyone use Motion for down conversion with good results?”
    MOTION has a very good DOWNSCALING filter (inherited from SHAKE) called LANCZOS. You won´t find it in Filters but in the “Image Units”.
    Still SHAKE offers better options than MOTION and works in 32b FP (MOTION doesn´t works FP).
    rafael
  • Nico Scott
    July 31, 2012 at 11:12 pm
    thanks for info. Haven’t been able to get me hands on shake so I’ll give this a shot. After reading some other posts I found using AE and applying a small amount of Gaussian blur before down scaling quite effective, as long as you add a sharp mask on the newly created files.
    I’ll let you know how i go.
    thanks
  • Nico Scott
    August 1, 2012 at 1:27 am
    I’ve just tried out LANCZOS scaling in Motion, however it seems a bit messy as I couldn’t figure out an easy way to scale down my 1920×1080 footage to PAL 720×576 (16:9) so it was precise. I just had to change the project settings then drag the slider and reposition the image to sit inside the frame.
    Is there something I’m missing?
  • Nico Scott
    August 23, 2012 at 1:26 am
    For those who may stumble upon this thread…
    I have since decided after many, many tests, that for the moment my best workflow when downscaling is using Compressor (using frame controls of course!)
    It’s a shame that it takes such a ridiculous amount of time, but seems to yield the best results for my workflow.
