Activity › Forums › Apple Final Cut Pro Legacy › prores 4444 level shifts
Posted by Dan Luke on February 20, 2010 at 2:14 amI’m exporting motion graphics from motion as QT prores 4444 files. If I import them into FC 7, add it to a sequence, match frame somewhere in the middle, make a still from the resulting match and insert it into the motion graphic, the level on the still shifts.
If I export the motion graphic using the dv codec, no shift. Whats up with that?
Rafael Amador replied 16 years, 6 months ago 5 Members · 9 Replies -
David Roth weiss
February 20, 2010 at 2:28 amDan,
I have no idea, but you left out an important piece of info above. What are the sequence settings you’re dropping the ProRes graphic into?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Russell Lasson
February 20, 2010 at 2:45 am[dan luke] “If I export the motion graphic using the dv codec, no shift. Whats up with that? “
DV is a superior codec to ProRes 4444…… jk
When you export to ProRes 4444, try changing the gamma correction on “none”.
-Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net -
Rafael Amador
February 20, 2010 at 2:46 amI have just arrived to Prores 444, so no experience, but the compressor have a Gamma option.
Try both ways.
Rafael -
Dan Luke
February 20, 2010 at 3:25 amChanging gamma correction from automatic to none makes the level shift worse.
David Roth weiss
February 20, 2010 at 4:21 amDan,
My inclination is always to look to DV compression as the culprit. If you’re done editing, try changing the compressor in Sequence>>Settings to ProRes, then re-render, then grab you still and see if there’s a color shift.
Do you see where I’m going?
David Roth Weiss
John Pale
February 20, 2010 at 6:42 amHmm. ProRes 444 can be either YUV or RGB….perhaps some sort of conversion is not happening when creating the still from the original (which may be RGB coming out of Motion)
Rafael Amador
February 20, 2010 at 7:22 am[John Pale] ” ProRes 444 can be either YUV or RGB…”
Yes, but we don’t know in which circumstances.
Same about 12b.
When and how?
Rafael
