Activity › Forums › Apple Final Cut Pro Legacy › Prores 4444 export from FCP has gamma shift
Posted by John Palmer on July 18, 2011 at 2:45 pmHi!
I am working with Prores 4444 files in FCP 7. I have done my color correcting through 3-way Color Correcter and am now trying to export quicktime.
I am choosing Quicktime Export with current settings with make movie self-contained clicked. (So there is no conversion at all)
But the resulting movie is much lighter than what’s in FCP. Seems like a gamma shift.
This never happened with Prores 422 before, am I missing something?
J
Evan Burns replied 15 years ago 4 Members · 16 Replies -
Rafael Amador
July 18, 2011 at 5:53 pmHi John,
If your Prores444 comes from Color or AE, is 10b RGB.
FC can´t render in 10b RGB so not sure how manage the process.
Set your sequence to Prores HQ and¨”Render in high Precission” may works.
rafael -
Jeremy Garchow
July 19, 2011 at 2:27 amYou should be checking this on an extenal monitor through proper hardware, but make sure that the FCP color compatibility box is checked in QT.
John Palmer
July 19, 2011 at 10:14 amWhere is the FCP color compatibility box in QT?
I am not doing a QT conversion, so not sure how that relates. I am simply exporting the sequence with “current video&audio settings.” When I do the same kind of export with ProRes 422 footage there is no shift. So I don’t feel this has anything to do with my monitor/hardware.
John Palmer
July 19, 2011 at 10:17 amThanks Rafael.
My footage comes from 5D, converted using 5DtoRGB. I’ve tried your method but it didn’t work. I get the same gamma shift as before. Did you have any other suggestions?
thanks!
j
Jeremy Garchow
July 19, 2011 at 12:15 pm[John Palmer] “Where is the FCP color compatibility box in QT?”
In the preferences of QT7.
ProRes 444 for 5D material is ultra overkill.
John Palmer
July 19, 2011 at 12:25 pmActually not. Try converting a file into 4444 and 422, look side by side, and you will see a major difference. At least I can with my footage.
If you’d like, you can read further here: https://www.elskid.com/blog/5d-to-rgb-new-transcoding-app-tested-at-home
j
Jeremy Garchow
July 19, 2011 at 12:35 pmI’ve tried it. There’s a reason it’s free.
Your tests dont compare 444 vs 422, but rather streamclip vs 5dtoRGB.
John Palmer
July 19, 2011 at 3:42 pmSorry James, read this one as well. https://www.elskid.com/blog/5d-to-rgb-the-follow-up-bigger-comparison-yes-yes-prores-422-sq
In any case, I made my own tests converting to both 4444 and 422, and I can see a clear difference on my calibrated Eizo 211 monitor.
You mention that 5DtoRGB is free. Is there a paid product that does a better job at converting? If so, could you let me know the name?
I had a discovery. When I export using “Quicktime conversion” from FCP, then there is no gamma shift. When I export using “Quicktime ” from FCP, there is a shift. Seems like a bug to me. Or there is a magical setting somewhere…
j
Jeremy Garchow
July 19, 2011 at 3:52 pm[John Palmer] “I had a discovery. When I export using “Quicktime conversion” from FCP, then there is no gamma shift. When I export using “Quicktime ” from FCP, there is a shift. Seems like a bug to me. Or there is a magical setting somewhere…”
There is no way to accurately judge this accept on a calibrated monitor through proper hardware out of FCP. My bet is that you don’t have a 444 capable monitor, is that right? how do you have the Eizo hooked up? Not through a Kona I imagine?
Do you have QT 7 installed?
John Palmer
July 19, 2011 at 3:59 pmYou’re right, I’m not sure if my monitor is 444 capable. It’s 12 bit, but is meant for photography and not video. so not sure beyond that…
https://www.eizo.com/global/products/coloredge/cg211/index.htmlno I don’t have a kona connection..
I have QT7 installed yes.
