Activity Forums Adobe Premiere Pro Prores 4444 equivelent on PC
  • Prores 4444 equivelent on PC
    Posted by Ben Edwards on August 3, 2014 at 11:57 am
    OK, so quite a bit of research has led me to think there is no prores 4444 equivalent on the PC. There is a prores 422 HQ (i.e. Avid DNxHD) and if you buy Avid you get a DNxHD 4444 but not with the free/LE Avid codecs.
    Is this correct? What would be a good alternative to use for 4444.
    I realise 4444 is overkill for a lot of things and this is discussed in lots of places. I am simply interested if there is a PC alternative.
    Ben
    Ben Edwards – Freelance Picture Editor
    https://www.funkytwig.com
    i5 3550 3.3Ghz, Windows 7 / Mac Lion, Nvida 550 Ti, 16GB Mem
    Walter Soyka replied 12 years, 1 month ago 2 Members · 1 Reply
  • Walter Soyka
    August 4, 2014 at 3:39 pm
    [Ben Edwards] “There is a prores 422 HQ (i.e. Avid DNxHD) and if you buy Avid you get a DNxHD 4444 but not with the free/LE Avid codecs.”
    Avid’s main DNxHD page links to an outdated version of the DNxHD codec (2.3.7).
    You can download the current version (2.3.9) here:
    https://avid.force.com/pkb/articles/en_US/download/Avid-Codecs-LE-2-3-9
    Please note: if you are using CC or higher, you can use Adobe’s DNxHD implementation in an MXF wrapper. It includes an RGB/4444 variant.
    One significant limitation of DNxHD’s current implementation is that it only supports HD; it does not support 4K or arbitrary frame rasters. I really like GoPro’s CineForm codec for these uses.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
