Activity Forums Adobe After Effects Prores 4444 Color Problem
  • Prores 4444 Color Problem
    Posted by Emre Mutlu on May 31, 2021 at 5:54 pm
    Hi there,
    I’m working on 32bit linear workflow. Everything is ok while working in After Effects but when i render my comp with alpha i got color difference. When i import it again it looks different from my comp. I tried to use color profile converter but the result is different still.
    Got any idea how i can fix this issue? If so could you please explain what i’m doing wrong?
    Walter Soyka replied 5 years, 3 months ago 3 Members · 3 Replies
  • Chris Voelz
    May 31, 2021 at 6:23 pm
    When you re-input the video are you disabling color mgmt?
    Also I think the answer may be in the second screen shot, the way I’m reading it is that on export it’s doing a gamma shift from 2.2 to 1.0.
  • Emre Mutlu
    May 31, 2021 at 6:38 pm
    Do you mean disabling “Use Display Color Management”? If so i’ve tried with it but couldn’t figure it out.
    What’s the proper way of doing this? I’m sending my project also.
  • Walter Soyka
    June 1, 2021 at 6:24 pm
    If you render to ProRes 4444 directly through Adobe Media Encoder instead of through the Render Queue, does it make a difference?
