Prores 4444
Posted by Neal Tate on June 1, 2012 at 3:01 amI am pretty sure Vegas can render to 422 with the avid codec, but is there a way to render 4444? Sorry if this has been asked already.
Gravitate Media Group (GMG)
gravitatemediagroup@gmail.com
http://www.youtube.com/gravitatemediagroupDave Haynie replied 14 years, 3 months ago 4 Members · 3 Replies -
Angelo Mike
June 1, 2012 at 3:49 amNot that I’m aware of. Vegas can indeed render to 422, though, both with an Avid plugin (that’s free to download) or in one of the profiles for mpeg2 rendering.
Steve Rhoden
June 1, 2012 at 3:56 amHere is the download link for the codec:
https://avid.force.com/pkb/articles/en_US/Compatibility/en372311Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956 -
Dave Haynie
June 1, 2012 at 6:54 pmVegas can usually only render with alpha channel (the fourth “4”) to uncompressed or uncompressed-ish formats. That’s because you rarely want an alpha channel with any lossless compression, as you can imagine. I use this all the time for animation projects.
Some add-ons allow 4:4:4:4 rendering. Cineform does, and I think Avid DNxHD as well. For most project, though, the alpha layer is simply meaningless.
In theory Apple gear can render ProRes, that’s a proprietary Apple format. The license it out to some hardware companies. But I recently came across this program: 5DtoRGB (https://rarevision.com/rarevision.com/5dtorgb/index.php). It’s a freebie, and claims to produce proper Apple ProRes from an AVC input file (at least… maybe other formats, haven’t tried it). I have used it occasionally to put AVC into DNxHD directly. The author wrote this primarily to convert HDSLR video (Canon 5D, thus the name) into “something else”. I think this using the ffmpeg engine and ProRes CODECs developed in the open source community for libavcodec (the thing VLC uses to decode everything without the need to install Windows CODECs, and much of the basis for video on Linux).
I have not actually had the need for ProRes, so I don’t know how well this works. But something to try, it you must have ProRes.
-Dave
