Activity Forums Apple Final Cut Pro Legacy ProRes 422HQ Not optimized warning?
  • ProRes 422HQ Not optimized warning?
    Posted by Rafael August on December 16, 2010 at 11:35 pm
    I up-converted several tapes through a matrox2 LE box using the Matrox ProRes 1920×1080 setting. I am now importing these up-converted files into a new project and several of the files prompt a not optimized warning recommending to recapture for multi stream playback.
    The tapes I captured were Beta SP tapes and PAL DV Cam. Why would I be getting this warning. I thought Pro Res was optimized for multi stream playback.
    Any help is much appreciated,
    Rafael
    Rafael August replied 15 years, 9 months ago 3 Members · 3 Replies
  • John Heagy
    December 17, 2010 at 12:14 am
    We get that all the time with movies captured with our custom app. It could be something as simple as a movie not having a UUID. Next time you get that warning check if FCP updated the modified date after import. If so it punched something into the file… I hate when it does that. Last thing we want is FCP corrupting clips just to dot an “i”.
    Bottom line… the warning never amounted to anything.
    John Heagy
  • Jeremy Garchow
    December 17, 2010 at 1:34 am
    Agreed.
    It can sometimes happen when the footage importing doesn’t match the timeline or hardware video output settings for whatever reason (codec/bit depth/whatevers). Hit ok and keep working.
  • Rafael August
    December 22, 2010 at 1:27 am
    What I have found is that it is very inconsistent. I have imported folders which have prompted warnings then reimported the same folder and received no warning. Thanks for your suggestions.
    Rafael
