Activity Forums Adobe Premiere Pro ProRes 422 won’t import.
  • ProRes 422 won’t import.
    Posted by George Strother on November 22, 2012 at 11:48 pm
    Premier 5.5, Win 7, QT Pro 7.7.3
    Importing ProRes 422 1920×1080 30p clips shows unknown format. Thought the codec came with QT?
    Then installed Apple ProRes QuickTime Decoder for Windows. No improvement.
    Clips have picture and sound in VLC player on the same computer.
    How can I fix this?
    George
    Light Images
    Phillip Scoggins replied 13 years, 8 months ago 5 Members · 5 Replies
  • Dennis Radeke
    November 23, 2012 at 12:24 am
    QT does include all ProRes decoders. That’s a tricky one. Try cleaning your cache and trashing your prefs to start.
  • Jeff Pulera
    November 23, 2012 at 2:57 pm
    With CS5, there was a bug that if the ProRes clip had 4-channel audio, it would not import. I believe the initial release of CS5.5 still had the bug, but was fixed with the first patch, so please make sure your Premiere is updated and see if that helps
    Jeff Pulera
    Safe Harbor Computers
  • Richard Knight
    November 25, 2012 at 11:55 am
    I had some ProRes files sent to me from a Post House that would not import into Premiere. It seems their Mac did not put on the .MOV extension I just added this and all was OK.
    Richard Knight
  • George Strother
    November 25, 2012 at 5:22 pm
    Thanks for the suggestions. I will not have access to the Premier suite until Monday, but I opened and inspected some clips on my FCP home system.
    The files in the folder labeled ProRes 422 are actually XDCAM HD422 50Mbs .MOV files. This just might not be a ProRes problem.
    I have downloaded XDCAM Viewer to a card and will install it Monday. Any other suggestions?
    George
    Light Images
  • Phillip Scoggins
    January 17, 2013 at 5:36 pm
    so how to I import .mov Pro res 422 1920×1080 files created on the AGA KiPro Rack system, into Adobe Premiere CS6?
