Activity › Forums › Apple Final Cut Pro Legacy › ProRes 422 video transitions won’t work
John Fishbackreplied 17 years, 7 months ago 3 Members · 25 Replies
Jeremy Garchow
January 18, 2009 at 7:46 pmIt’s because you don’t have enough handles in the clip. Try trimming the head off of a clip (at least a second) I bet you can put a transition. The first answer you got was correct.
Jeremy
Peter Dunphy
January 18, 2009 at 7:51 pmThe thing is, this is my ‘final’ version, graded and synched to the soundtrack. If I cut off a few frames from the beginning and end I’m worried the whole thing will go out of synch…otherwise I’d be more than happy to take off a second from each clip, you know?
If I removed a second from a clip there’d be a ‘nothing’ space between it and the next clip, with only the audio (speaking at a lecture) running in the background. Or, would the transition be clever enough to stretch across that one second (max) gap do you think?
I’m a bit of a newbie to Final Cut I’m afraid :o/
Jeremy Garchow
January 18, 2009 at 7:55 pmWhere’d the grading come from? COlor? Sounds like you didn’t render with handles if that’s the case.
Jeremy
Peter Dunphy
January 18, 2009 at 8:03 pmYep from Color – ouch I missed that handles bit altogether! Thanks – looks like you’ve nailed it!
Should I now:
1. Go back into my graded project Color and ‘render with handles’ (hadn’t heard about this in my video tutorial) then send the rendered sequence back to final cut?
Any idea how I might be able to render with handles please?
2. Do something in Final Cut? eg. resend afresh to Color and grade from scratch?
Really appreciate your help.
Peter
Jeremy Garchow
January 18, 2009 at 8:09 pmGO in to your current Color project and renreder with handles.
It’s in the Setup > Project settings tabs.
Peter Dunphy
January 18, 2009 at 8:11 pmPhew! You’re a gentleman, thanks for your help. Will get cracking!
Peter Dunphy
January 18, 2009 at 8:25 pmOne last thing…is there a value I should use for handles apart from the standard one I’m seeing which is 00:00:00:00 ?
Have googled to no avail :o)
I saw something in this article about adding handles in FInal Cut prior to sending to Color?
Jeremy Garchow
January 18, 2009 at 8:39 pm[peter dunphy] “is there a value I should use for handles apart from the standard one I’m seeing which is 00:00:00:00 ? “
It needs to be more tyhan 0 as that’s what got you in to this trouble in the first place. How long is your longest transition? That’s how much handles you should add. 3 seconds I bet would do it.
That’s 00:00:03:00
Jeremy
Peter Dunphy
January 18, 2009 at 8:50 pmYou’re a legend it works!!!!
Thought I was never going to make it out of this one alive!!!
Thanks Jeremy and John for all you valuable help and for making Creative Cow such an incredible resource.
All the best
Peter
Peter Dunphy
January 19, 2009 at 1:49 amOkay I did the 3 second handles and re-rendered the project. Unfortunately the maximum duration for a transition length is 1 frame. I’ve tried typing in a numeric value and tried dragging the transition to extend it but no joy. FCP allowed me to make one ‘normal length’ transition between the 1st and 2nd clip but that was it :o)
Despite all kinds of dragging and all attempts to enter numeric values the transition keeps returning to a duration of 1 frame.
Any further suggestions would be really appreciated.
Peter
EDIT: for this issue I found the following additional info useful, for anyone else with the same problem (the info’s at the bottom of the page):
https://www.geniusdv.com/weblog/archives/final_cut_pro_dissolves_operation_not_allowed.php
