Activity › Forums › Apple Final Cut Pro Legacy › ProRes 422 render slightly lowers brightness
  • ProRes 422 render slightly lowers brightness
    Posted by Michael Macinnis on March 17, 2011 at 5:59 pm
    My source file is encoded with ProRes 422. I cut out one scene and rendered the file using Current Settings (as ProRes 422 again) but when I compare the render to the original, the luminance of the render is slightly lower than the original footage. I’ve tried changing the Gamma correcting in the advanced sequence settings to both Automatic and None but it has no affect on the render. I double checked to make sure the Video Processing was set to 10-bit YUV and it was. All I want is a 1:1 copy of the my original footage minus the one scene I’m cutting out. Thanks.
    Michael
    Michael Macinnis replied 15 years, 6 months ago 2 Members · 2 Replies
  • Michael Pfost
    March 17, 2011 at 6:18 pm
    I’ve run into this same issue, but never found a solution. What version OS are you using?
  • Michael Macinnis
    March 17, 2011 at 7:41 pm
    I’m on 10.5.8
