Activity Forums Apple Final Cut Pro Legacy ProRes 422 Render Codec question (Sequence Settings)
  • ProRes 422 Render Codec question (Sequence Settings)
    Posted by Holden Kim on January 28, 2011 at 2:56 pm
    Hello
    I’m currently editing XDCAM HD footages and I have a question about Render Codec. This has been bugging me for a long time and I’ve tried to find the answer somewhere but no luck. So here we go.
    When I bring in a XDCAM HD footage onto the timeline, I let the FCP match its setting. And when I go check the Sequence Settings, under General tab, QuickTime Video Settings’ Compressor is set to XDCAM HD 1080p30, and under Render Control tab, Codec is set to Same as Sequence Codec.
    Now, I heard that somewhere that “edit natively but render in ProRes so it’ll take less time rendering”. Does that mean I should only change the Codec setting under Render Control tab to Apple ProRes 422 or change the QuickTime Video Settings’ Compressor to ProRes 422 as well? Or QuickTime Video Settings only matter when I export? I’m also asking this because it’s weird when I ONLY have XDCAM HD footages on the timeline and change these two setting mentioned above, they all playback in real time. But when I tested the same thing on a completed project with all the graphics on top of video tracks and such, each of these changes made the timeline go red, resulting no realtime playback. Am I doing something wrong?
    I’ve also tried to transcode all the XDCAM HD footages to ProRes 422 even before I start editing, but that takes awfully long time and hard drive space and I’m not sure if that’s quite a way to go about editing this. Can anyone tell me what’s the best workflow of XDCAM HD edit in ProRes 422?
    I’d really appreciate your answers. Thanks for the help in advance.
    Holden Kim replied 15 years, 7 months ago 2 Members · 4 Replies
  • Michael Kammes
    January 28, 2011 at 3:30 pm
    A few things:
    You can do you edit in XDCAM as you normally would. When you are done with your Edit, change the sequence render settings to ProRes and re-render. That will take all the footage and effects in your timeline and render it out to Pro Res.
    I’ve always been on the fence with XDCAM. If it’s cuts only, low track count, very little effects or color work, it’s fine. Otherwise I prefer doing a pre-encode into Pro Res before I start editing.
    As far as your timeline going Red…that’s expected if you are mixing codecs in the timeline. Mixing Pro Res, XDCAM, and graphics files is difficult for FCP to do in real time.
    ~Michael
    .: michael kammes mpse
    .: senior applications editor . post workflow consultant
    .: audio specialist . act fcp . acsr
    .: michaelkammes.com
    Hear me pontificate: Speaking Schedule .
  • Holden Kim
    January 28, 2011 at 4:21 pm
    Thanks, Michael for the quick answer. I’m sorry for my ignorance but what’s the benefit of editing in XDCAM and “re-render” after changing the render codec setting to ProRes? Would it be better if I change the render codec setting to ProRes first and edit away?
    Don’t I need to change the QuickTime Video Settings’ Compressor setting to ProRes if I want the final QuickTime exported movie to be ProRes? Because when I left my Compressor setting to XDCAM HD, the QuickTime movie was exported to XDCAM although my Render Codec was set to ProRes? Does that make sense? I’m sorry if I’m confusing you. It’s because I’m confused too.
  • Michael Kammes
    January 28, 2011 at 5:18 pm
    The benefit of editing natively in XDCAM is that you can load the disc and/or files and begin editing right away. You cannot do this if you transcode to Pro Res before you edit. What you are essentially gaining is time.
    The benefit of rendering in Pro Res is that the quality and color space of the render will be better, due to the compression scheme Pro res utilizes compared to XDCAM.
    If you change the render codec to Pro Res, and your timeline sequence settings are set to XDCAM, you will render into Prores, but FCP may not play it back in Real Time because your sequence is set to XDCAM. FCP like having things all in harmony for optimal playback.
    The final export setting is dictated when you go to FILE–EXPORT. All other settings dictate what FCP uses while it’s running (timeline, render, etc.)
    ~Michael
  • Holden Kim
    January 28, 2011 at 6:18 pm
    Thanks for the elaborated answer, but I’m not sure if some of your answers are 100% true. For example:
    When QuickTime Video Settings’ Compressor is changed to ProRes, it exports ProRes. In the same way, when it’s set to XDCAM HD, it exports XDCAM HD. I’m strictly talking about File-Export-QuickTime Movie here, not File-Export-Using QuickTime Conversion. So correct me if I’m wrong, but I think I have no choice but to change the Compressor setting to ProRes if I want the completed full-res video in ProRes.
    Anyway, let me get this straight. I’m just gonna write down these steps in order and please tell me if I’m doing anything wrong. The POINT is I want the most efficient and best way to edit XDCAM HD footages using ProRes 422 codec, hopefully in final video in ProRes codec as well.
    Steps:
    1. Use XDCAM Transfer program downloaded on Sony website to transfer XDCAM HD footages.
    2. Import them into FCP browser, drag one of the clips to timeline and let the FCP match the setting automatically. That gives me (XDCAM HD 30p in Compressor setting and Same as Sequence Codec in Render Codec setting)
    3. Then change the Render Codec setting to ProRes and leave the Compressor setting alone for now.
    4. Edit and finish it then when I need to export full-res QuickTime Movie, change the Compressor setting to ProRes (??, and render it again?)
    This way, I get to edit natively, which in my case XDCAM HD, and still render faster using ProRes codec. Does this sound about right? Or on step 3, should I change the Compressor setting to ProRes and edit so I don’t have to re-render again after it’s finished? (note: I’m NOT talking about transcoding all the footages and bring them into FCP here.)
    Thanks again for your help. It’s really helping me a lot. I’m just not there yet, still need some stuff cleared.
