Activity › Forums › Apple Final Cut Pro Legacy › prores 422 or prores 422 hq
Posted by Marc Poliquin on May 2, 2010 at 4:06 pmHi:
I mostly edit with footage shot on the XDcam pmw-ex 3 and the XDcam pmw-350. Projects are usually corporate, non-broadcast.
I normally convert to prores 422 hq, but if I’m not outputting to anything larger than 1920×1080, would I be better off editing in standard prores 422?
I haven’t found a straight answer to this.
Thanks.
M.
Rafael Amador replied 16 years, 4 months ago 4 Members · 7 Replies -
Shane Ross
May 2, 2010 at 5:26 pmHQ is for 10 bit and 2K or larger formats only. Your camera records 8-bit.
https://forums.creativecow.net/faq/applefinalcutpro#75
Shane
Read my blog, Little Frog in High Def -
Marc Poliquin
May 2, 2010 at 7:03 pmDoes it really matter if you render after the fact or render non-prores source out of Compressor, and then start editing? You’re still converting to prores at some point.
Marc Poliquin
May 2, 2010 at 7:22 pmSorry, I should’ve said that I was already working in a Prores timeline.
Bret Williams
May 3, 2010 at 2:56 amSo you convert all of your media to ProRes and then start editing? Why? You can edit an xdcam sequence and only render to prores the parts that require any rendering. Dissolves, graphics, etc. Converting everything to prores before you start eats up quadruple the harddrive space, requires more power and faster drives to play back the files (means less rt effects) and takes time. XDcam and HDV are the only two shooting codecs in which FCP has this special workflow. Seems crazy not to take advantage of it.
Rafael Amador
May 3, 2010 at 9:34 amThere is only one reason to compress a signal: Economy.
Use always the less compressed format that you can afford.
rafael
