Activity Forums Apple Final Cut Pro Legacy “PRORES 422 in QUICKTIME” For Dummies
  • “PRORES 422 in QUICKTIME” For Dummies
    Posted by Aurelien Moryusef on June 25, 2011 at 12:55 am
    HI there.
    Sorry, I’m one one those dudes asking the same eternal questions people ask… This one is about color loss between FCP and QT working with Prores 422 codec… More than anything, my post is meant to ask: “DID I REALLY UNDERSTAND WHAT I READ ?”
    -My machine is a 2.2 Ghz Intel Core i7 Laptop, with its AMD Radeon HD 6750M graphic card.
    -I have no External screen. The only one I got is a 5 year old VGA….. so I don’t use it.
    -I’m editing a 1h30 diaporama exported initially from Iphoto in Prores 422. My goal is to make various outputs: a full def QT file, a Blu-ray DVD compression, SD DVD etc…
    As you understood i turn crazy because i CAN’T get my QT file read correctly, in any application (mpeg streamclip, QT…). Colors are heavily washed out.
    I read a few things here and there, but still don’t know what I should do.
    QUESTIONS
    1) If I understand well, it looks bad on a mac, but it’s normal, right? It doesn’t mean that the export is bad in itself, it is just a matter of display??? If that’s it, at least it gives me a little peace.
    2) Now, if i want to play that QT movie i exported from FCP on a flat screen via an HDMI portable drive, will it display OK? (asuming the screen is correctly setup).
    3) If I want to make a dvd compression in Compressor, doing a few color adjustments as I always do… it means I cant do it right? Because Compressor will show me that deceptive washed out image.
    Did I understand well the issue?
    Isn’t there ANY way for people in my case (I.E “broke”), to SEE the actual colors of the file created in FCP?
    If no… how much would it cost me to have a decent display solution? Is it still workable with that laptop? (a 17 inches from 2011 series).
    Thanks a lot
    Aurelien a.k.a “prores for dummies”
    Aurelien Moryusef
    Editor
    Caracas, Venezuela
    Rafael Amador replied 15 years, 3 months ago 2 Members · 3 Replies
  • Rafael Amador
    June 25, 2011 at 9:11 am
    Hi Aurelien,
    Is nothing about platforms, applications or codecs; is about monitoring.
    Whatever thing you do to correct your picture, your only reference is your computer monitor.
    So you will be always correcting “for your” monitor, but in fact you may be screwing the picture.
    The only valid reference is an external pro monitor.
    Adjusting with a pro monitor, you know how your picture will look in every pro monitor properly adjusted.
    But you won’t know how will look in any other screen (computer, TV) till you play it there.
    rafael
    http://www.nagavideo.com
  • Aurelien Moryusef
    June 27, 2011 at 2:58 pm
    Hi Rafael
    Thanks for your quick answer, which confirms I had understood well the problematic of working with prores.
    All the best
    Aurelien Moryusef
    Editor
    Caracas, Venezuela
  • Rafael Amador
    June 27, 2011 at 8:47 pm
    Hi Aurelien,
    There is another issue that I haven’t mention: Gamma.
    The shift you see may be just about how the picture is displayed in different players.
    The same file may looks very QTPlayer, VLC, Mpgstream, or Compressor viewer.
    Your best option to see if there is a real color change or gamma shift is bringing and comparing the stuff in FC Canvas (100% size, full quality rendering, etc). Another good option is Color.
    make sure that when you render Prores, the sequence is set to render in High Precision.
    rafael
