Activity Forums Apple Final Cut Pro Legacy ProRes 422 HQ vs 422 for D5 workflow
  • ProRes 422 HQ vs 422 for D5 workflow
    Posted by Elizabeth Czyzewski on February 22, 2010 at 10:55 pm
    Hello,
    I am starting on a project that was shot on a Canon D5. I am aware that we must convert the footage from H.264 to ProRes 422 to cut with, but I was wondering if it is advantageous at all to convert to ProRes 422 HQ instead?
    Thanks.
    Russell Lasson replied 16 years, 7 months ago 6 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    February 22, 2010 at 10:56 pm
    According to Gary Adcock, you should stick with 422 from 8 bit footage.
    Jeremy
  • Russell Lasson
    February 23, 2010 at 1:44 am
    Plus the h.264 files are so compressed to start with, trying to see if there is any difference at all between the compression of ProRes HQ and SQ would be very difficult.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Elizabeth Czyzewski
    February 23, 2010 at 2:43 am
    The reason I was leaning toward the HQ is because I think the filmmaker will want to mess around a bunch with the color and look of the piece and it’s my understanding that the image holds up a lot better with HQ than with SQ when it comes to digital image manipulation. Is this valid?
  • Andrew Kimery
    February 23, 2010 at 2:52 am
    I haven’t done a side by side test but you should be able to manipulate HQ more, but I think your limitation is going to be the source footage and not the difference between ProRes and ProRes HQ.
    -Andrew
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
  • Jeremy Garchow
    February 23, 2010 at 3:06 am
    [Elizabeth Czyzewski] “The reason I was leaning toward the HQ is because I think the filmmaker will want to mess around a bunch with the color and look of the piece and it’s my understanding that the image holds up a lot better with HQ than with SQ when it comes to digital image manipulation.”
    ProRes and ProRes HQ are both 10bit. There’s no more color space or bit depth, just more data rate. This isn’t going to help anything, but it will increase your file size.
    Since you are starting from a highly compressed 8bit RGB image, HQ is not going to help much. Really, it’s not.
    Yes, HQ is compressed less, but your starting point is so low, ProRes HQ can actually do more harm than good.
    Read this for more info:
    https://provideocoalition.com/index.php/apple/story/prores_a_closer_look/
    Jeremy
  • Russell Lasson
    February 23, 2010 at 6:48 am
    [Jeremy Garchow] “Since you are starting from a highly compressed 8bit RGB image, HQ is not going to help much. Really, it’s not. “
    Jeremy is totally right here. If you want better color correction, shoot on a format that has less compression.
    -Russ
    Russell Lasson
    Color Mill
    Salt Lake City, UT
  • Gary Adcock
    February 23, 2010 at 2:48 pm
    [Andrew Kimery] “I haven’t done a side by side test but you should be able to manipulate HQ more, but I think your limitation is going to be the source footage and not the difference between ProRes and ProRes HQ. “
    I have Andrew and I could not agree more
    from 8 bit originals the only issue becomes generational. (ie: the more times it is re-encoded after renders) when you are talking about ProRes vs HQ.
    I only use HQ in 3 instances.
    a) Recording a Live signal direct from the camera (not previously recorded material)
    b) Transcoding footage from certain cameras that record at 444 10bit or Higher
    ***RED, Phantom, ARRI(D21,Alexa), f35(S-log only), SI-2K and of course Film originals***
    c) Projects that start in the manner above I know are going to Filmouts (not HD DI, Not HDcamSR, real honest filmout usage only.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
    February 23, 2010 at 7:32 pm
    Great! As far as Compressor goes, I’ll just use the Apple ProRes 422 compression setting (but change compression type from 422HQ to 422). It seems strange for that to be the default as opposed to 422. Any idea why that is?
    February 23, 2010 at 7:37 pm
    And I guess it’s wise to double check – are there any settings that I should change from what the Apple ProRes 422 (not HQ) defaults would be?
  • Adam Claude jones
    February 24, 2010 at 4:43 am
    Interesting thread, I’m subscribing.
    Carry on.
