Activity › Forums › Adobe Premiere Pro › Prores 422 HG with CS5 or CS5.5
Posted by Robert Buncher on October 20, 2011 at 1:45 pmI am starting a new project on which all of the files will be recorded to Prores 422 HQ on a Aja Ki Pro Mini Compact Field Recorder.
I currently have PP CS5 on my MacPro and would like to know if there is an advantage to upgrading to PP CS5.5 before starting the project.
BobRobert Buncher replied 14 years, 11 months ago 3 Members · 5 Replies -
Jeff Brown
October 20, 2011 at 2:27 pmI only upgraded recently, but Premiere 5.5 does seem to be more responsive, particularly when reading image sequences (the bulk of my work). I’d say it is the perfect time to upgrade.
-jeff
Jeff Pulera
October 20, 2011 at 4:07 pmNot sure about Mac, but on the PC side, Premiere has had issues accepting ProRes files with 4-channel audio, which was just fixed with the latest update for CS5.5
I run CS5 at home and the 2-channel ProRes files from the Ninja recorder work great, while 4-channel clips give me a “File not supported” error when attempting import.
Jeff Pulera
Safe Harbor Computers -
Robert Buncher
October 21, 2011 at 1:40 amYeah, I just tried to import the first ProRes files into CS5 and got that “file not supported” error. I guess I should update.
Can I just copy the files from the CF card or do I need to make a Disk Image?
BobMacbookPro 2.33 2gb os 10.4.11
FCP 5.1.4 After Effects Bootcamp XPpro -
Jeff Pulera
October 21, 2011 at 1:48 pmHi Bob,
Not sure what KiPro uses for a file directory structure, but best practice is to copy over the works intact – do not rename any files or folders. This is especially true with the new AVCHD format cameras, copy the works over and do not alter anything, or linkages get broken between audio, video, metadata, all that.
Jeff Pulera
Robert Buncher
October 21, 2011 at 3:51 pmThanks Jeff.
I have another question but I think I will start a new thread for it.
Bob
