Activity › Forums › Apple Final Cut Pro Legacy › Prores 422 for SD as well?
Posted by Arnljot Bringedal on July 26, 2007 at 5:07 pmHey!
I normally edit Dv in an uncompressed timeline….
But:
Could I use prores instead, even though the footage is SD?
( Save space this way? )If yes – which prores quality setting?
If no: What timeline setting is best for DV Sd – if Im gonna do alot of grading etc..?
Thanks guys!
*** Norwegian videojournalist & Editor***
Gabriel Watson replied 18 years, 10 months ago 6 Members · 9 Replies -
Jeremy Garchow
July 26, 2007 at 5:34 pmYup. ProRes HQ is 10 bit, ProRes Regular is 8 bit. Use HQ.
Jeremy
David Roth weiss
July 26, 2007 at 5:45 pmIndeed there are SD ProRes settings, and because they are 10-bit they will provide benefits for you, especially in preserving your graphics, and possibly some benefits when color grading.
Because you are in PAL land, the two 625 25 ProRes settings are your choices — one is (HQ), the other is normal. Check them out, I’ll bet they’re both very good. I would imagine you won’t need the HQ setting, which probably yields larger file sizes without any discenable change in quality.
David
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY
David Roth weiss
July 26, 2007 at 5:47 pmOkay then, regular is 8-bit… Still bet you won’t see much difference.
David Roth Weiss
Jeremy Garchow
July 26, 2007 at 5:59 pmLet’s just say we will agree to disagree on that one David.
I always opt for 10 bit.
David Roth weiss
July 26, 2007 at 10:50 pm[JeremyG] “Let’s just say we will agree to disagree on that one David.”
Not really… I use 10-bit too whenever doing anything that’s important.
David Roth Weiss
Chris Borjis
July 27, 2007 at 12:21 amSo is the HQ prores 10-bit and the non-hq 8-bit?
or is it medium quality (non-hq)
Dejan Spagnut
July 27, 2007 at 1:52 pmAre the ProRes PAL SD timelines upper or lower field? Or can you actually choose field order with ProRes codec?
Uncompressed timelines are upper field in PAL and DV is lower field and that makes it extremely confusing when using dv footage in uncompressed timeline, so I am interested if ProRes can help us overcome this inconvenience?
Gabriel Watson
October 18, 2007 at 12:37 pmapply shift field filter on the clips, in 5.1 FCP did it automaticly, not sure if it does it in 6
