Activity › Forums › Apple Final Cut Pro Legacy › ProRes 422 Files Blurry in FCP7 Canvas?
  • ProRes 422 Files Blurry in FCP7 Canvas?
    Posted by Maya Rudolph on January 13, 2014 at 5:53 pm
    Hi all,
    I am using FCP7 to edit ProRes 422 files. The files look great in the viewer, but appear pixelated and blurry in the canvas. I did an export test and they also export in the same blurry way.
    The clips are 1910×1080 ProRes 422s converted from MTS files using Anusoft Video Converter.
    I believe the issue is that the 422s are too large for the FCP timeline/canvas, but I’m not sure how to compress them without losing quality. Any advice will be highly appreciated!
    Shane Ross replied 12 years, 8 months ago 2 Members · 3 Replies
  • Shane Ross
    January 13, 2014 at 6:35 pm
    What are your sequence settings?
    [Maya Rudolph] “The clips are 1910×1080 ProRes 422s converted from MTS files using Anusoft Video Converter.”
    1920×1080 I hope. From what source?
    [Maya Rudolph] “I believe the issue is that the 422s are too large for the FCP timeline/canvas”
    Hardly. FCP is designed to work with full res, 1920×1080 ProRes 422, HQ or even 4444 files. I suspect your sequence settings are some other, lower quality setting, like DV/NTSC.
    Shane
    Little Frog Post
  • Maya Rudolph
    January 16, 2014 at 4:21 am
    Thanks for your help.
    Yes, they’re 1920×1080, converted from MTS files from a Lumix GH2.
    What should I try resetting the settings to?
  • Shane Ross
    January 16, 2014 at 5:42 pm
    They need to match your clip. If you drop a clip into a blank sequence, FCP asks if you want the settings to match. Click YES.
    Shane
    Little Frog Post
