Activity › Forums › Apple Final Cut Pro Legacy › Prores 422 CPU requirements
  • Chris Borjis
    April 9, 2008 at 9:54 pm
    I believe even a G4 cpu has no problem.
    The higher power is needed when digitizing.
    G5 quad is listed as the minimum, but mine fails / drops frames everytime.
  • John Pale
    April 10, 2008 at 3:32 am
    My dual 2ghz G5 can’t play it back reliably at all (ProRes HD, anyway…SD is fine). Dropped frames galore. Its all CPU…., I can play uncompressed 1080i HD no problem.
    I think any Intel unit like yours would work fine.
