Activity Forums Apple Final Cut Pro Legacy Prores 422 Audio Render issues
  • Prores 422 Audio Render issues
    Posted by Ian Durkee on February 25, 2011 at 4:38 pm
    First, thanks for being a fantastic resource.
    When I bring prores 422 (not HQ) clips into a sequence in FCP 6 I have to manually render the audio each time. What could I be doing wrong?
    Steve Knattress replied 15 years, 7 months ago 4 Members · 5 Replies
  • Chris Tompkins
    February 25, 2011 at 7:35 pm
    Is your audio 48k? Aif or Wav?
    Chris Tompkins
    Video Atlanta LLC
  • Ian Durkee
    February 25, 2011 at 9:24 pm
    I believe it is AAC. I took some H264 footage and applied the prores 422 settings in compressor before bringing it in to FCP.
  • Chris Tompkins
    February 26, 2011 at 12:38 pm
    In the Browser it will give you the specs on the audio.
    You probably need to re-do em so they are 48k, 16bit, aif’s
    Then there will be no audio issues for you.
    Chris Tompkins
    Video Atlanta LLC
  • Jeff Greenberg
    February 26, 2011 at 4:37 pm
    I’m assuming that these ProRes Clips were pushed through compressor – the compressor preset for transcoding does pass through audio – leaving you with AAC audio. You’ll have to redo them with Linear PCM, 16 bit, stereo for FCP to work with them in RT.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Steve Knattress
    March 1, 2011 at 3:39 pm
    What was your original file format from your camera?
    I have a headcam which produces H464 video files, the audio is recorded at 16Khz.
    Playing the unconverted camera clip in QT and select the show window>movie inspector will tell you.
    As stated above compressor by default does nothing to the audio when converting to ProRes, you need to set the converted audio to 48KHz.
    Steve
