Activity Forums Adobe After Effects ProRes 422 artifact
  • ProRes 422 artifact
    Posted by Tim Wells on November 2, 2011 at 8:41 am
    Hi
    I have footage that has come of an Arri Alexa, in Apple ProRes 422, (which is what Arri recommend). I have imported this footage into AE and begun trying to key out the greenscreen, using Keylight 1.2. I’m getting artifacts within the image that are causing problems. I had a pro take a look and he has said that everything looks right to him that the problem is in the codec itself.
    Any idea whats gone wrong?
    Tim
    Tim Wells replied 14 years, 10 months ago 3 Members · 5 Replies
  • Walter Soyka
    November 2, 2011 at 3:09 pm
    ProRes is a pretty robust codec, well-suited for keying.
    Can you post a screen shot showing your problem?
    Walter Soyka
  • Brad Wright
    November 2, 2011 at 5:22 pm
    I have seen plenty of artifacts with both ProRes 4:2:2 and 4:4:4:4. I’ve seen some blocky squares in the keying that don’t exist in the actual footage. For the very best results, use an image sequence of 16 bit TIFF files or something uncompressed 4:4:4:4.
    Brad Wright is software engineer, so often hard to figure out what he is talking about. He is always happy to explain answers further.
  • Walter Soyka
    November 2, 2011 at 5:30 pm
    [Brad Wright] “For the very best results, use an image sequence of 16 bit TIFF files or something uncompressed 4:4:4:4.”
    But this won’t be an option now — it sounds like the footage was recorded to ProRes.
    Walter Soyka
  • Brad Wright
    November 2, 2011 at 5:40 pm
    If he client has the ARRI raw files, you be able to use that.
  • Tim Wells
    November 6, 2011 at 4:52 am
    Thanks guys
    Sorry I didn’t reply sooner, it was indeed the prores 422 files, I’m working with the 4444 now and it’s a nice clean image. The after effects I am having to use doesn’t work with LUTs either but once I had done some color correction I got a very nice key, now just the fun of cleaning up some green spill:)
    Thanks again for your feed back.
