Activity › Forums › Apple Final Cut Pro Legacy › ProRes 422
ProRes 422
Posted by Harry Bingham on February 22, 2011 at 1:05 pmSo to use footage in FCP, I cant use mp4 as I get the out of memory message. So I see the norm is to convert it to ProRes 422, however, this reduces the size from full HD 1920 x 1080 (from my Canon 550d) to 720 x 576. I want my video to be full HD. What am I doing wrong?
Thanks.Jeff Greenberg replied 15 years, 7 months ago 5 Members · 7 Replies -
Richard Harrington
February 22, 2011 at 3:13 pmYou’re choosing the wrong preset
ProRes supports all flavors of HD. Look at which setting you are choosing carefully and make sure your source is full HD too
Richard M. Harrington, PMP
Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
Dino Vince
February 22, 2011 at 3:42 pmYou can also change sequence settings for individual sequences. I’d suggest you go thru all of the presets/sequence settings/etc. to get a feel for what’s there and how to use them. Good luck!
Harry Bingham
February 22, 2011 at 3:51 pmI went into the codec settings and upped the resolution from 720 x 586, to 1920 x 1080 (I’m using adobe media encoder if that’s any consolation) and though, yes problem solved. However the encoded video is just 720 x 576 footage dropped on a 1920 x 1080 black background. Bit like letterboxing, but there’s black banners at the sides as well as top. Hope I’ve made that understandable.
Harry Bingham
February 22, 2011 at 3:59 pmIm going to upload a screenshot of my settings, tell me what im doing wrong. Im in UK so need to use PAL preferably if thats any help.
1663_screenshot20110222at15.57.32.png.zip
Chris Tompkins
February 22, 2011 at 7:31 pmThat is a horrible picture of your settings…
You should be converting HD files to HD files ProRes. No SD.
Chris Tompkins
Video Atlanta LLC -
Harry Bingham
February 22, 2011 at 11:12 pmSo what settings do I need to change? That’s what im asking, as far as I can tell, that is HD settings?
Jeff Greenberg
February 23, 2011 at 3:16 amYou could use compressor which already is set up for this…
In AME, pick any QuickTime setting and adjust it to
Video Codec: ProRes 422, 1920×1080 (if you want 1080), quality @ 100, frame rate matching your frame rate, Aspect Square, field type upper first
Audio codec: Uncompressed 48k, stereo 16 bit.Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com
