Activity › Forums › Apple Final Cut Pro Legacy › ProRes 422
ProRes 422
Posted by Greg Ball on January 19, 2008 at 4:33 pmI don’t see the ProRes 422 option in my easy set-up. I’m on FCP 6.0.1 on a Mac G5 Quad with an AJA OEM card that came with my Media 100 Hde system. Shouldn’t it be in the easy set-up
menu? I’d love to take advantage of it. Any thoughts?Rafael Amador replied 18 years, 8 months ago 4 Members · 5 Replies -
Walter Biscardi
January 19, 2008 at 4:40 pmNot sure if it will work with that AJA board.
With FCP 6.0, you now have multiple layers of options in the Easy Setup room. ProRes is not available for every frame rate, every format I don’t believe.
I know you’ll see Pro Res in NTSC SD 29.97 and HD 720 or 1080.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Greg Ball
January 19, 2008 at 5:00 pmThanks Walter, I’m editing Beta SP footage at NTSC SD 29.97. Usually 8-bit uncompressed. Do you think there’s any software updates available for that or am I just plain out of luck?
I was hoping to digitize about 6 hours of interviews to edit while saving drive space. -
Walter Biscardi
January 19, 2008 at 5:12 pm[Greg Ball] “Do you think there’s any software updates available for that or am I just plain out of luck?
I was hoping to digitize about 6 hours of interviews to edit while saving drive space.”The ProRes presets are just installed as part of Final Cut Pro. If you don’t see the codec at all, then the software was not installed correctly.
As for the card working, you would have to call AJA Tech support and ask them.
Gary Alan
January 19, 2008 at 5:23 pmI think I read that sometimes you need to reinstall the AJA (or update to the latest) to get the presets to show after installing FCS.
Gary
Mac Pro 3Ghz Intel Dual Duo, 6GB RAM, 30″ ACD
MacBook Pro 17″
Sony XDCAM EX with a Sachtler Tripod System -
Rafael Amador
January 20, 2008 at 7:30 pmIf you have installed FC after installing the AJA, you better reinstall the AJA drivers.
PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
