Activity › Forums › Maxon Cinema 4D › ProRender Motion Blur
  • ProRender Motion Blur
    Posted by Bradley Orzechowski on October 29, 2018 at 5:35 pm
    I’m working on a short animation in C4D using ProRender. I have an issue with some of the objects not looking good with motion blur activated, but other objects look phenomenal with the blur. Is there any way to apply that blur to one specific object, or is it an all-or-nothing type scenario?
    Steve Bentley replied 7 years, 10 months ago 2 Members · 1 Reply
  • Steve Bentley
    November 5, 2018 at 1:07 am
    Is there a reason you are using Pro to render? You can add a motion blur tag to only the objects you want to blur but you may have to go back to the standard render for that. (we don’t use Pro because it takes waaaaaay too long).
    You can also render out the blur separately with an object ID (multichannel format like EXR) and then extract the blur in post from only the objects you want blurred.
