Activity Forums Maxon Cinema 4D ProRender HDRI gamma weirdness
  • ProRender HDRI gamma weirdness
    Posted by Sam Hains on August 9, 2019 at 12:55 am
    Weird… it seems that HDRI lighting is causing super brightness in the picture viewer/disk render but not in the viewport render???
    Reproduce the issue:
    1. Place a camera, light, cube and a sky in the scene.
    2. turn on prorender as your renderer
    3. render the scene in your viewport using ProRender->StartProRender
    4. render the scene to your picture viewport
    The picture viewer render is considerably brighter than the viewport render. By enabling a filter I can see it is about 0.5 gamma difference across them.
    Why is this happening? It seems like this is not an issue when I use normal lighting/not HDRI sky.
    THanks 🙂
    Sam Hains replied 7 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
