Activity Forums Blackmagic Design ProPresenter to ATEM (black part of Lowerthird is keyed out)
  • ProPresenter to ATEM (black part of Lowerthird is keyed out)
    Posted by Femi Adesoji on June 11, 2021 at 12:35 pm
    How do I stop ATEM from keying out the black part of my lower third, I’ve tried adjusting the gain on the luma key tab and cropping which affects other graphics.
    thanks
    Chad Pearson replied 5 years, 2 months ago 2 Members · 1 Reply
  • Chad Pearson
    June 11, 2021 at 3:33 pm
    A luma key, by definition, uses the black and non-black parts of your image (aka the luminance) to determine what to key out. Anything that is black is removed.
    Instead, try using a chroma key to select a different color to key out, like blue or green, and setting that as your Screen Color in ProPresenter’s Display preferences.
    Alternatively, you will need to purchase either a UltraStudio or Decklink output device and use ProPresenter’s Alpha Key module instead.
    Setting up an Alpha Key output from ProPresenter – Renewed Vision
  • carmen rodriguez
    January 9, 2024 at 4:00 pm
    I’ve the same problem with Blackmagic ATEM.
    can somebody help me PLEASE
