Activity Forums VEGAS Pro Proposed DAW build
  • Proposed DAW build
    Posted by Jeff Levesque on June 26, 2010 at 2:51 pm
    Hello All,
    I have just been introduced to Sony Vegas software and am quite impressed. I am planing on using it for live recording with the following proposed build.
    I would like feedback from users with firsthand experience in DAW simultaneous multitrack recording. Specifically, I would like to know if this system will be able to record 24 tracks at 192KHz sampling rate simultaneously.
    Video editing (if any) will done on a different machine.
    Newegg Wish List with full list of components can be viewed here:
    https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=19432188
    Thanks in advance for any input.
    Motherboard: GIGABYTE GA-870A-UD3
    CPU: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz HDZ955FBGIBOX
    Memory: G.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 1333 (PC3 10666) Model F3-10666CL9D-8GBRL
    OS Hard Drive: Intel X25-V SSDSA2MP040G2R5 2.5″ 40GB SATA II MLC Internal Solid State Drive
    Storage Hard Drive: Western Digital Caviar Black WD1501FASS 1.5TB 7200 RPM SATA 3.0Gb/s 3.5″ Internal Hard Drive
    Audio Interface: MOTU PCIe 424 with two HD192 audio interfaces
    OS: Windows 7 Professional (64 bit)
    Recording Software: Sony Vegas Pro 9.0
    Steven Talley replied 16 years, 3 months ago 2 Members · 1 Reply
  • Steven Talley
    June 27, 2010 at 11:42 am
    I’d get a larger SSD, maybe 80 to 120gb. Plugin’s and additional software will eat up a 40gb drive. “They” say that an SSD will last longer if it has plenty of open space to sequentially use the available space evenly. Don’t know if it’s true but it sounds logical.
    I’d get a good video card with dual 1200dpi monitors. Screen real estate is always a good thing. Vegas’s components can be setup in custom views across multi monitors for maximum benefit.
    Lastly, plan on external hard drives for backing up all your work as you progress with each project. Portable USB hard drives are cheap and big enough for these tasks.
    Enjoy the new system.
