Activity Forums Apple Final Cut Pro Legacy Property Conflict
  • Property Conflict
    Posted by Kimberly Ruane on November 20, 2008 at 8:43 pm
    Hi all,
    Okay, here’s the setup.
    The editor has the big system, and I’ve got my laptop.
    He cuts his stuff, then passes it to me for audio cleanup.
    We each have a set of drives that we work from, with all media mirrored.
    We’ve had no problems with 90 scenes of a feature, but we got one today.
    When copying my sequence back into his project, we got a popup that said:
    “A master clip already exists for a clip you are adding to this project, but some of its properties do not match those of the clip you are adding. Choose how you want to resolve this conflict from the options below.”
    Then it lists the clip I am ADDING and the EXISTING clip.
    Here’s the thing: its listing an A Cam clip and a B cam clip as if they’re the same thing.
    The clips HAD been multiclipped, and the multiclips used to cut, but that wouldn’t cause this, would it?
    I’m very confused, and we need help quickly!
    Director’s Cut is due Friday!
    Kim
    Kimberly Ruane replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
