Activity Forums Apple Final Cut Pro Legacy Properly logging and capturing separate clips – Details?
  • Properly logging and capturing separate clips – Details?
    Posted by Joni Church on December 15, 2005 at 9:15 pm
    Hello all,
    I’m trying to explain the importance of logging and capturing clips separately- especially when one is planning on re-digitizing- to an editor at another post-house with whom I’ll be working with shortly. I keep facing his argument:
    “Yeah but it takes more time to log everything than it does to find what I need in the captured clip after the fact, and I could miss a good clip in the log process.”
    Frustrating, yes. I wonder if any of y’all could point-form out a good clean list of the benefits of properly logging and capturing separate clips, as well as the possible negative effects of capturing entire tapes in one clip. I’m just having such a hard time convincing him…I think it might help to have some backup.
    Thanks a lot for any help.
    Joni Church replied 20 years, 9 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    December 15, 2005 at 9:34 pm
    This subject is kind of subjective and kind of not. SOme reasons are technical, and some are preferential. I can only give my advice as to how I like to work and it may or may not apply to all. The technical reasons are more cut and dry.
    There are times when I am editing on site and there simply is not time to log and capture. I need the footage in the system and I need it yesterday. It usually means I spend more time dividing up the clip later into subclips and renaming, but I do it as I need it, not before.
    If I have the time at the studio, I choose to log and capture as I can look at the list of clips with their log notes and know exactly what I have. Also, if the other editor in the office and I are tag teaming a project (which happens from time to time) he can then sit down to my project and know pretty much what each shot is before he even has to look at it, while I can sit down to a project that he has started and do the same thing. This is helpful if he didn’t watch any of the footage while it was digitizing. I feel as if when i log and capture I know everything I have because I am watching almost every frame shot. If i digitize the whole tape in one pass, there’s more of a chance I’ll miss something if the phone rings, an email comes, the door bell rings, etc. If I do remember a shot in a half hour clip that I have digitized at once, then it takes me that much longer to find it by sorting through a 30 minute clip. If it is logged and captured correctly and I can simply do a find for what I want or quickly scan the browser/log notes for the clip I have described.
    NLE systems (in my experience) seem to get less bogged down if there are shorter clips to work from. When you start getting clips that are too long, the system really starts to drag, especially on slower firewire drives and uncompressed projects. If you are working in DV, then it’s not a huge deal as the data rate of DV is pretty low and doesn’t bog the system too much. There’s also less chance of sync errors on shorter clips, but this isn’t really an issue for most people anyway.
    I hope this gives you a good place to start.
    Jeremy
  • Shane Ross
    December 15, 2005 at 10:14 pm
    When I log and capture, I log and capture everything, just in smaller chunks. I don’t leave anything out, so I don’t get that arguement.
    If you are capturing a long clip, and say at min 45 the capture process stops for some reason, loss of power, drive crash, FCP crash…you have to re-capture that whole 45 minutes again. If you log and capture in like, 10 min chunks, then you only have to redo 5 minutes of capture.
    If for any reason you lose some media (it’s been known to just vanish) you have smaller chinks to capture.
    Sometimes, depending on the camera used at the shoot, sync will tend to drift. Smaller chunks keeps the audio in check.
    You get to know your footage better. Very important for an editor
    Shorter clips to scrib thru…if you have one large clip, and you scrub too fast, you might miss the 10 second shot you are looking for.
    ORGANIZATION. The key to a successful project is organization, and having several clips with good descriptions is easier to search thru than long clips with not-so-good descriptions. A tape can contain several different locations and subject matter. LOGGING each clip means noting what footage you have.
    SUBCLIPS are problematic when it comes to onlining, or recapturing a project. Especially with the current state of the Media Manager.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Joni Church
    December 16, 2005 at 2:59 pm
    Thanks guys.
    Yeah, I can’t claim I’ve never chosen to capture a whole tape in one pass, but I sure prefer logging and capturing smaller chunks for it’s organizational and technical benefits. I try not to insist that everone do things “my way,” but when I’m onlining somebody else’s project I just like evrything to be as efficient as possible. Hopefully your posts will help me plead my case with the editor over at the other post house.
    Thanks again,
    Joni
