Proper workflow for Avid project from Pro-Res proxies ?
So I’m starting up a project that was shot on Red and the DIT synced the pic and audio in Resolve and then made Pro-Res proxies. The proxies have all the audio tracks on them. Except for the first day or two due to technical issues, the audio timecode matches the pic timecode.
I would like to cut on Avid MC, so I tested out transcoding one clip using MC and it seems as if this will be fine as long as I copy the start tc into the sound tc column for the days where it matches. One weird thing is if I load the transcoded clip into the source monitor, on the timeline tracks it shows the name as Aslot, but when I cut it into a sequence, the sequence timeline tracks show the clip name.
So the steps I’m thinking I need to do is:
AMA the clips in Avid MC
transcode to DNx36HD and PCM for the audio
change the new clip name to the slate (scene & take)
copy start tc into sound tc column
fill in sound roll columnI made an EDL and it has all the correct info, the camera file name and clip name are there, the tc is correct…
If I go this route, is there anything I’m missing that I should be concerned about? And for the days where the sound tc doesn’t match the pic, is the Pro-Res able to have/know the sound tc or does it only have one tc for the QT? I haven’t found a clip that has the audio burn-in not matching the pic burn-in and I haven’t talked to the DIT yet as they are in another time zone.
Is there any reason I should do this in Resolve instead of MC?
And lastly, I have MC 5.5.5 on my system right now but have purchased MC 8.x.x. I have yet to download and install it as I was finishing up a short film and had no need to. Is there any reason I can’t start transcoding in MC 5.5.5 and take the bins into MC 8.x.x? Honestly, I am probably going to install MC 8 tomorrow morning, but if for some reason I don’t yet…..
I guess I should mention that I have FCP7 and Premiere 6. FCP7 I’ve used and dislike, Premiere I have not really used and especially have not done project management or turnovers to sound/mx etc. I know I will cut much faster using Avid and I know my way around it so as not to cause problems. Is there any reason I should abandon my Avid love and try Premiere out?
Thanks for any input!
