Activity Forums Apple Final Cut Pro Legacy Proper tape specs for tv distribution
  • Proper tape specs for tv distribution
    Posted by Mallnu on May 11, 2005 at 2:22 am
    I will be doing onlines for some :30 tv spots in hd shortly and will be sending our masters in hdcam and digibeta for distribution. I don’t know a few things necessary for this which our dubbing house previously took care of. first, what is the proper sequence of bars+tone, black, slate and countdown and are the final cut bars correct for this for both formats. Also, when outputting to digital formats, should the video have setup? thanks so much for any help.
    Mallnu replied 21 years, 4 months ago 3 Members · 5 Replies
  • Graeme Nattress
    May 11, 2005 at 2:28 am
    Digital video never has, does not have and never will have any setup. Setup is only for analogue NTSC video in North America.
    Graeme
    http://www.nattress.com – Film Effects for FCP
  • Tony
    May 11, 2005 at 2:50 am
    To avoid confusion in SD make sure the bars recorded on the HD masters are 75% saturation not 100%.
    The timing I have used for air masters is as follows
    1) timecode is DF
    2) black from 58:00:00- 58:30:00
    3) one minute bars and tone 58:30:00- 59:30:00
    4) black 10 sec 59:30- 59:40:00
    5) ten sec slate 59:40:00-59:59:50
    6) Countdown 59:59:50-59:59:57
    7) Programs starts at 01:00:00:00
    Never send out discrete audio tracks for broadcast they should either be mixed down to mono or stereo depending on what the broadcaster has requested.
    Setup is only for analog formats such as betacam sp, vhs, 1″, Umatic etc.
    Tony Salgado
  • Mallnu
    May 11, 2005 at 3:37 am
    thank you both so much for the info. now you say you use drop frame. is this the standard? i have previosly always output in ndf.
  • Tony
    May 11, 2005 at 3:52 am
    DF timecode is the standard for broadcast programming.
    However for short material such as 30 sec spots NDF or DF will be ok.
    DF is essential for program masters such as 1/2 hour or longer in which the exact time (in reference to clock time) is necessary for the proper timing of commerical insertions or program breaks.
    Tony Salgado
  • Mallnu
    May 11, 2005 at 6:13 am
    Thanks Tony for clearing that up.
