Activity Forums AJA Video Systems Proper RGB 10-bit setup?
  • Proper RGB 10-bit setup?
    Posted by Andrew Dietz on December 14, 2009 at 9:17 pm
    I am having issues when editing RGB 10-bit sequences. Any effect/filter throws the levels off. Black will go from 0mV to 50mV anytime an effect or transition is applied.
    Does anyone have any other specific information that might help me when setting up a project with these settings?
    I am capturing/outputting using easy setup RGB 10-bit DL, but capturing SMPTE range (it defaults to Full for some reason).
    System Specs: FCP 7.0.1, OS 10.6.2, Kona3 7.1 Video processing is set to: Always Render in RGB.
    Andrew Dietz replied 16 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
