Activity › Forums › Apple Final Cut Pro Legacy › Proper Project settings for P2 and Firestore?
  • Proper Project settings for P2 and Firestore?
    Posted by Don Wilson on May 11, 2006 at 8:50 am
    I have an HVX200 recording to P2 cards in 720/24pn, the camera set to 720/24p when recording to the Firestore FS100. Wanting the film-look, and an outside chance it will on day go to film. Should I set project and sequence in 720/60 or 720/24 ?
    Also, the Panasonic Frame Rate Converter software does not seem to convert audio. If not, how the heck do you convert the Firestore 720/60 footage to 720/24 with audio?
    Many thanks,
    Don Wilson
    Shane Ross replied 20 years, 4 months ago 2 Members · 1 Reply
  • Shane Ross
    May 11, 2006 at 8:56 am
    [Don Wilson] “Should I set project and sequence in 720/60 or 720/24”
    720p24. With this setting you can remove the pulldown and get 24fps.
    [Don Wilson] “how the heck do you convert the Firestore 720/60 footage to 720/24 with audi”
    After you convert the clip and lay it into the timeline, you will have to go back to the main clip and slow it down 40% to match, then drop it into the timeline separately.
    Shane
    Alokut Productions
    http://www.lfhd.net
