Activity Forums Broadcasting Proper audio level
  • Proper audio level
    Posted by Pinner on February 26, 2006 at 11:53 pm
    Just curious after setting the bars and tone to -20db or 0vu, is there a standard or a safe level I should set the main body of the show to not to peak above? Some say not to peak above -9db some say -12. THanks
    Nina Staum replied 20 years, 6 months ago 3 Members · 2 Replies
  • Bouncing Account needs new email address
    February 27, 2006 at 12:34 am
    [Pinner] “Some say not to peak above -9db some say -12.”
    “Some” and “some” are both right, if they are consistent within the project.
    So pick one peak level and stick to it.
  • Nina Staum
    March 2, 2006 at 4:08 pm
    Problem with digital VU’s is that there doesn’t seem to be the same agreed-upon standards as there are with analog, so correct levels are a bit subjective. I have always gone with average peak at -15, never ever anything over -10. That’s how I was taught to dub stuff for air as a master op, and that’s how I now master shows as an editor. Never had any complaints from broadcasters and those levels will give you a perfect dub across to Beta SP if you set tone to 0.
