Activity Forums Adobe After Effects proper 24p 1080i workflow
  • proper 24p 1080i workflow
    Posted by Cherlique Lilienthal on February 5, 2011 at 4:28 am
    I just started using my first HD 24p camcorder. i used to work with a panasonic pv-gs120 3CCD camcorder and i could do pretty amazing stuff with it. i understood the work-flow very smoothly but sinds i started working with footage from the hv40, i started to run in a bit of trouble. in after effects when i drag and drop the clip into the create a new comp button the frame rate is 29.97 and the footage looks stretched vertically. i tought that the comp was supposed to taken on all the properties of the footage when dragging into the button. i can manually change this but should i? or do i use another comp preset? also is there some kind of blending mode or motion blur i should be using to make the 24p look really smooth?
    Joey Foreman replied 15 years, 7 months ago 3 Members · 2 Replies
  • Simon Bonner
    February 5, 2011 at 1:35 pm
    Sounds like AE isn’t recognising the properties of your imported footage. Select your footage in the Project panel and you will see the properties of the footage displayed at the top of that panel. If you know these are incorrect, you can change them manually. Right-click the footage in the Project panel and choose Interpret Footage > Main. Alter the frame rate and pixel aspect ratio as appropriate. When you add the re-interpreted footage to a new comp, you should find it looks as expected.
    Adding an incorrectly interpreted item to a new comp and then changing the comp settings to match the footage isn’t the best way to do it.
    Simon Bonner
    youtube.com/simonsaysfx
  • Joey Foreman
    February 5, 2011 at 8:04 pm
    I’m thinking the footage is being interpreted okay, it’s just that AE is displaying the native resolution in the comp window, rather than the display res. You can toggle on the pixel aspect correction button at the bottom of the comp window to see the correct display resolution.
    As to frame rate, hmmm… I’ve never seen AE improperly interpret the frame rate. Field order occasionally, but not frame rate. Perhaps this footage was accidentally shot 1080i?
    One other thing – if you’re running any version of AE prior to CS5, this footage will not work properly in its native HDV format, and will need to be converted to one that AE can work with.
    Joey Foreman
    Editor/Compositor/VFX Artist
