Activity Forums Adobe After Effects Proper 16-235 becomes 30-218 when uploaded on Youtube
  • Proper 16-235 becomes 30-218 when uploaded on Youtube
    Posted by David Stutzmann on December 12, 2015 at 4:55 pm
    Hello everyone,
    I’m new to color management and after one week of watching tutorials, searching forums and running tests, I feel completely lost.
    I use After effect and Premiere pro on Windows 7.
    I color corrected my video in premiere pro, which uses a 0-255 luma range if I’m correct.
    Then I export it as H264 .mp4, import it in After Effect and set the color space to Rec. 709 (16-235). I rectify the contrast a little bit, save and use Media encoder to encode the video as H264 .mp4. When I watch it with Media Player Classic, it looks exactly as in the preview so everything is ok so far.
    At that point, here are the specs of the video:
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 2s 0ms
    Bit rate : 63.8 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.003
    Stream size : 15.6 KiB (15%)
    Language : English
    Encoded date : UTC 2015-12-12 13:50:35
    Tagged date : UTC 2015-12-12 13:50:35
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    However, when I try to upload it on Youtube, pure black, which was 16, becomes 30 and pure white, which was 235, becomes 218.
    So my guess is that either Youtube doesn’t care which color space you used and crops everything to 16-235, even if it’s already been done ; or I missed something and failed to have youtube recognize that my video was already at a legal color format.
    Which brings me to a second point : if youtube scales everything to 16-235 then how can this person’s t-shirt be more than black (level 1, when it should logically be 16 !!!) : https://www.youtube.com/watch?v=n0PUiC_bfE4
    What do you think?
    Thanks.
    David Stutzmann replied 10 years, 8 months ago 4 Members · 4 Replies
  • Chris Wright
    December 13, 2015 at 5:18 am
    the missing puzzle piece is that youtube doesn’t support color management in the first place. I recommend burning in the 16-235 with utility profile converter and turning off color management altogether for web uploads.
  • Ivan Myles
    December 13, 2015 at 10:05 am
    Welcome to the forum and thank you for including detailed information in your post. The root cause might be related to your AE color management settings, but there are several issues with your workflow.
    • What format are your captured (source) files? If Premiere Pro is having trouble injesting, consider transcoding to a standard intermediate format based on a 422/444 10-bit all-intra codec such as ProRes, DNxHD/MXF, AVC-I, or Cineform. If the source files are 8-bit RGB then PNG or JPEG2000 image sequences will also work.
    [David Stutzmann] “I color corrected my video in premiere pro, which uses a 0-255 luma range if I’m correct.”
    • Using Premiere Pro for color correction is fine. Although its settings are presented as 8-bit RGB the internal color processing supports RGB or YCC (YUV) at up to 32-bits depth per channel. Check that all effects support your preferred color pipeline, otherwise Premiere Pro might be processing internally as 8-bit RGB.
    • The first priority is making sure the RGB channels are within 0-255, and this shouldn’t be a problem if your source footage was captured from an 8-bit RGB display. Use the YC Waveform, RGB Parade, and Vectorscope video scopes when setting color levels. If the source footage is YCC, make sure the Y and RGB channels are within 0-100 IRE on the scopes. In practice, I like to set peak luminance around 90-92 IRE to have enough headroom to keep the peak RGB levels under 100 IRE.
    • Are you checking the footage to make sure levels look good throughout each clip? Sections of video that are all black or desaturated are likely caused by settings made earlier. Use multiple keyframes to manage levels through the entire duration of each clip.
    [David Stutzmann] “Then I export it as H264 .mp4, import it in After Effect and set the color space to Rec. 709 (16-235).”
    Going to After Effects might be unnecessary and H.264 definitely is a poor choice of intermediate codec. H.264 is a high compression delivery codec. You are losing a lot of color information when exporting with 4:2:0 color subsampling. This results in a loss of detail and increases the likelihood of color blocking and banding. Use a Dynamic Link between AE and Premiere Pro or export an intermediate file in one of the formats listed above. If you are just tweaking contrast, though, try to do it in Premiere Pro and avoid the extra step to AE.
    [David Stutzmann] “here are the specs of the video:
    Bits/(Pixel*Frame) : 0.003”
    • That’s a problem. What export settings are you using? YouTube typically compresses to 0.07 bits/pel. I recommend uploading files at 0.20-0.40 bits/pel for best results. That correlates to 4.4-8.8 Mbps target bitrate for a 1280×720 25fps file. Set maximum bitrate to 1.5X-2.0X target and use 2-pass VBR encoding.
  • Walter Soyka
    December 14, 2015 at 3:18 am
    You should not have to manually limit your range. Try skipping this step.
    [David Stutzmann] “Which brings me to a second point : if youtube scales everything to 16-235 then how can this person’s t-shirt be more than black (level 1, when it should logically be 16 !!!) : “
    Video levels are supposed to be scaled back to full levels on playback with a full-level display.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • David Stutzmann
    January 10, 2016 at 1:47 pm
    Thank you for all your answers. I finally understood what was wrong.
    First, I understood that a video IS not “16-235” or “0-255” in absolute but rather “optimized for a display in 16-235 (or 0-255)”.
    So in premiere pro, I saw my video in a 0-255 space and it looked good. But I realized that my blacks were not always set to 0 so when the video was cropped to 16-235 on youtube, the blacks were too grey. The problem was solved by adjusting luminance and bringing the blacks to 0.
    And I did not actually have a problem with “super whites” or “super blacks” since Premiere Pro cuts them off. So when the video was displayed in a 16-235 space, nothing when out of this range unlike in the video I posted in the first message.
