Activity › Forums › Maxon Cinema 4D › Projector
  • Projector
    Posted by Andy Stokes on July 11, 2005 at 9:46 am
    Hi all,
    How can I make a projector ? I have applied a texture to a light and things work fine when I apply the texture to the alpha channel however i’d like to project a colour image.
    Any ideas ? Is there a shader that might be able to do this.
    Cheers,
    Andy
    Andy Stokes replied 21 years, 2 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    July 11, 2005 at 1:17 pm
    Put your texture in the the material’s transparency channel. If you want to see the light–like a projector in a dusty room–enable the light’s visibility>volumetric function in the light’s General tab.
  • Andy Stokes
    July 12, 2005 at 2:26 am
    Hi Adam,
    Thanks for your response. However I have already achieved this. What i’d like to do is to be able to project a colour image from a light onto objects in my scene. If I use the transparency channel I only get a b/w OR gobo effect from the light NOT a full colour image projected onto my objects.
    I hope this is clear.. Anyone else got any idea ?
    Thx,
    Andy
  • Adam Trachtenberg
    July 12, 2005 at 4:41 am
    [Andy Stokes] “Thanks for your response. However I have already achieved this. What i’d like to do is to be able to project a colour image from a light onto objects in my scene. If I use the transparency channel I only get a b/w OR gobo effect from the light NOT a full colour image projected onto my objects.”
    You sure about that?
  • Andy Stokes
    July 12, 2005 at 5:02 am
    Hi Adam,
    Thanks alot.. I was applying the texture to the alpha channel instead.. Got mixed up between transparency and alpha…Sorry for the confusion and thanks for your help..
    Cheers,
    ANdy
