Activity Forums Maxon Cinema 4D Projection in Material Tag interfering with Cel Shading
  • Projection in Material Tag interfering with Cel Shading
    Posted by Daniel Conrado on August 13, 2020 at 6:40 pm
    Hello everyone, this is my first post here.
    I know this is the place to get some help. I’ve been a frequent visitor of this page since ever. But now, I have a problem that I’ve never seen before in the forums.
    See, I am more like an Adobe AE user, so my knoledge in C4D is limited. I’m trying to make a Cel shading effect in some objects, but for some reason the light I set is not affecting the shade.
    Here the light is afecting the object as always.
    Then I add a material and set the Luminance and the Cel texture.
    But this is the result.
    After a couple of hours running a search in Google I found out that part of the problem is here, in the Projection attribute in the Material Tag. If I change this option the shade will change, but still no reacting to the light in the scene.
    Can anyone help me? Is there a step that I miss.
    Also, don’t seems that the problem is in the render settings nor the light itself.
    Thanks for your help.
    Daniel Conrado replied 6 years, 1 month ago 2 Members · 4 Replies
  • Brian Jones
    August 14, 2020 at 5:39 pm
    Inside the Cel Shader’s settings Uncheck – Camera and Check – Lights
  • Daniel Conrado
    August 14, 2020 at 5:52 pm
    Hello Brian,
    Thanks for responding. Unfortunately, still not working…
    Seems that the UVW mapping have something to do with this.
  • Brian Jones
    August 14, 2020 at 7:03 pm
    try rendering, the Interactive Render Region is good for this, what shows in the preview is not always what renders (it’s for great preview speed but a few compromises are made to do that)
  • Daniel Conrado
    August 14, 2020 at 8:26 pm
    Well, it does. It works with the Interactive Render Region. Thanks a lot Brian!
