Activity Forums DaVinci Resolve projection in cinema stuttering
  • projection in cinema stuttering
    Posted by Joe Otaku on May 8, 2025 at 3:24 pm
    I exported a video in Davinci at 25fps, every video in the timeline was at 25fps except 3 videos 1 in 60fps and 2 in 23.97fps the projector was set to 25fps in the cinema but my video stutter, How can I solve this choppy, stuttering image?
    Glenn Sakatch replied 1 year, 2 months ago 3 Members · 2 Replies
    May 8, 2025 at 4:04 pm
    Hey Joe,
    If your projector is locked at 25fps, then you deliver 25fps.
    Do make sure that you have the right “frame size” too.
    Also investigate whether you are in Progressive or interlaced mode?
    And, then there is the codec and playback, as if the drive can not “feed” the signal fast enough, it may stutter – like if you stream a video at home and it pauses from time to time, because it can’t buffer enough of the video for a smooth playback.
    Hope that this helps.
  • Glenn Sakatch
    June 7, 2025 at 3:32 pm
    Yes a bit more information on what type/size of file you are trying to playout, and what the playout system is setup for. I’m assuming you are not creating a dcp for the cinema, but instead trying to play a quicktime? If it is a DCP, then what bit rate did you use to create the dcp. (Bigger isn’t always better)
