Activity Forums Adobe After Effects “Projection” in AE
  • “Projection” in AE
    Posted by Amir Shachar on February 10, 2007 at 9:00 pm
    Hi
    I work with Adobe After Effects 7.0.
    I want to make a 3D projection of some clip. The “projector” should be placed behind the “screen.
    Which effects must I need to use?
    Amir
    Mike Clasby replied 19 years, 7 months ago 3 Members · 2 Replies
  • Nate Vander plas
    February 11, 2007 at 12:50 am
    [“The “projector” should be placed behind the “screen.”]
    You mean behind the AE camera I assume. Well, you might think that the beam effect would do it, but I personally wouldn’t be too happy with that look. Try this series of techniques:
    -put your video layer in the spot you want it (on the screen)
    -duplicate your video layer
    -apply a directional blur or CC radial fast blur to the duped layer
    -then use bezier warp to make the shine close to a point (at the projector)
    -you may have to do some masking as well
    This way you have a shine that corresponds to your video layer. Other than that you may want to try the strobe effect as well, depending on the look you’re going for.
  • Mike Clasby
    February 11, 2007 at 1:18 am
    I didn’t quite understand (that happens to me a lot) what you wanted either, but this from Philip is great (if it’s what you’re looking for), and it comes with a project file.
    Name: Filip Vandueren
    Date: Nov 6, 2006 at 6:52:26 pm
    Subject: Re: reversed shine effect ..like rays going from projector projecting to screen
    https://forums.creativecow.net/readpost/2/891127?
