Activity › Forums › Apple Final Cut Pro Legacy › Projecting Super Eight on wall
  • Projecting Super Eight on wall
    Posted by Richard Chenoweth on September 15, 2008 at 10:48 pm
    Hey everybody,
    I am projecting old Super-Eight, Eight, and Sixteen reels onto a wall and video-taping… it works
    fairly well…
    The projector is a GAF 1388. The video cam is a Canon Vixia HV30.
    The projection surface is a bright white sheet of 13 X 19 heavyweight matte print paper.
    I have adjusted and tweaked all surfaces and normals to eliminate “perspective”.
    The phenomenon I am getting is that the super-sensitive Canon is registering the flutter of the three-bladed GAF shutter wheel and creating a “fan-like” visual effect of dark-light fluttering. You can’t really see it on the pure projected movie on the wall, but the super-sensitive Canon registers this flutter and totally exaggerates it so that it’s pretty distracting.
    Anyone have a work-around on this effect?
    Many thanks!!
    Richard
    Lars Fuchs replied 18 years ago 4 Members · 6 Replies
  • Bill Dewald
    September 15, 2008 at 11:12 pm
    This is the FCP forum – perhaps you’d get better results in “Cinematography” or “Indie Film”.
    I’d try to manipulate the shutter on the video camera to get rid of those blades.
    I guess thats the added cost of a pro telecine – having a camera running in synch with the projector…
  • Richard Chenoweth
    September 15, 2008 at 11:19 pm
    Okay, thanks! I didn’t realize CC had those other forums…
    Rich
  • David Rowan
    September 16, 2008 at 2:51 am
    If your camera has settings to sync when shooting from a computer monitor they might also work with this issue.
    DWR
  • Lars Fuchs
    September 16, 2008 at 6:51 pm
    If the Vixia has variable shutter speeds, you should try to experiment with them. You’re dealing with a phase problem – your 3-bladed shutter produces 54 fps and 72 fps when running at 18 or 24 fps respectively, and I assume the camera is running at 29.97. Different shutter speeds can help mininimize the effect. The other way is to use a variable speed projector and manually ride the speed control to keep it as close to 20 fps as possible.
    Good luck!
  • Richard Chenoweth
    September 17, 2008 at 4:48 pm
    Thank you Lars,
    I cannot find out much about this old (1970s) GAF 8/Super 8 projector. Not adjustable.
    I assume it’s playing 24 fps then.
    The Canon Vixia has choices of 30 and 60 (and maybe 50?)
    So, I see… if the two systems can somehow be made a “multiple” of each other they could
    theoretically be in phase 24/72 or 24/48… I’ll try to find out more.
    My old 16 projector, a nice Singer Graflex, is much more sophisticated and may have a speed control.
    Thank you!!
    Richard
  • Lars Fuchs
    September 17, 2008 at 5:15 pm
    [Richard Chenoweth] “I cannot find out much about this old (1970s) GAF 8/Super 8 projector. Not adjustable.
    I assume it’s playing 24 fps then.”
    Don’t make that assumption. Its much more likely to be running at 18fps. That was the de-facto standard for Super 8mm. Only higher-end gear could do 24 fps, and there’s usually a speed selector on those models (both projectors and cameras). As far as I know there are no super 8 cameras that shoot 24 fps only; every camera I’ve ever seen (and I’ve seen a few) is either 18 fps only or 18/24 switchable. Some have other speeds as well, like 9 fps and 32 or 54 fps for slomo’s; but 18 fps is the common speed.
    Go to Onsuper8.org and scroll down to the bottom right. There you’ll find a bunch of diy telecine links.
    A common approach is to fix the projector’s frame rate to 20fps (giving you 60fps with a 3-bladed shutter, perfect for ntsc) by phase-locking it to the 60hz household AC current.
