Activity Forums Cinematography Projecting Super Eight on wall
  • Projecting Super Eight on wall
    Posted by Richard Chenoweth on September 15, 2008 at 11:20 pm
    Hey everybody,
    I am projecting old Super-Eight, Eight, and Sixteen reels onto a wall and video-taping… it works
    fairly well…
    The projector is a GAF 1388. The video cam is a Canon Vixia HV30.
    The projection surface is a bright white sheet of 13 X 19 heavyweight matte print paper.
    I have adjusted and tweaked all surfaces and normals to eliminate “perspective”.
    The phenomenon I am getting is that the super-sensitive Canon is registering the flutter of the three-bladed GAF shutter wheel and creating a “fan-like” visual effect of dark-light fluttering. You can’t really see it on the pure projected movie on the wall, but the super-sensitive Canon registers this flutter and totally exaggerates it so that it’s pretty distracting.
    Anyone have a work-around on this effect?
    Many thanks!!
    Richard
    Richard Chenoweth replied 17 years, 11 months ago 3 Members · 4 Replies
  • Jason Jenkins
    September 16, 2008 at 4:30 am
    Have you tried adjusting the shutter speed on the HV30?
  • Richard Chenoweth
    September 16, 2008 at 1:02 pm
    Jason, et al,
    Thank you for responding. Yes, I was able to make the speed on the Canon “TV 60” and it
    reduced the flutter appearance dramatically… Thanks!
    I think the key is that the speed of Projector (not adjustable on mine) should evenly divide
    into the speed of the Canon, so they are somewhat in sync… I think…
    I found this interesting site on how-to procedure for this:
    https://www.dvdhomevideoeditor.com/ARTICLES/TUTORIAL_howto_trans_8mmfilm.htm
    Best regards,
    Richard
  • Steven Bradford
    September 19, 2008 at 7:11 am
    It’s really worth it to get a Variable speed projector. They’re around. I paid about $75 for mine off ebay about 8 years ago. Of course a five bladed projector is even better, but you can get decent results with a variable speed that you can trim to just the right speed to go into the sixty fields a second.
    I also had much better luck projecting onto a matte GRAY surface (not textured) then onto a white surface. It helps control the contrast build, making it easier to control over exposure and clipping in the white areas.
    Steven Bradford
    http://www.seanet.com/~bradford/
  • Richard Chenoweth
    September 19, 2008 at 3:15 pm
    Great tips Steve… Thank you!!
    Richard
