Activity › Forums › Maxon Cinema 4D › Projecting Spline or better technique?
  • Projecting Spline or better technique?
    Posted by Donald Mitchell on September 13, 2006 at 5:01 pm
    I am modelling a photo realistic piece of packaging. It’s a leather tube that holds a whisky bottle. It has a rectangular label with rounded corners stuck on to it’s front that wraps round the tube. I’m trying to model the label so it has some thickness and wrap it round the tube. I’ve tried spline projection using a path created in illustrator but it seems to go all weird and distorted, and I’m now trying deformers. What’s the best way to handle this kind of thing?
    Thanks in advance.
    Adam Trachtenberg replied 20 years ago 2 Members · 1 Reply
  • Adam Trachtenberg
    September 14, 2006 at 4:05 am
    I would select the bottle polys where the label should go, run the split command, then select all the polys in the resulting object and do a very small “move normal” (just enough to avoid coplanar polys). Then do an extrude with the caps option selected.
