Activity › Forums › Broadcasting › Projecting DV content
  • Projecting DV content
    Posted by Aanarav Sareen on February 23, 2006 at 8:21 pm
    Hi all,
    A couple of years ago I produced a video for a client of mine and they really loved what I gave them. Now, it has been three years and they want to use the product that I made 3 years ago and project it on a large screen (around 60 inches or so). Now, my question is: although this was originally shot in SD DV, will there be a significant reduction in quality when projected on a large screen? Most of the footage is shot in the dark with minimal lighting (which is what the client wanted) and my initial guess says that there might be a few image degradation issues that I might have to deal with.
    So, if there does turn out to be a significant loss of quality, what can I do to eliminate part of the problem?
    Aanarav Sareen, ACE
    Adobe Certified Expert, Premiere Pro
    Aanarav Sareen replied 20 years, 7 months ago 2 Members · 3 Replies
  • Bouncing Account needs new email address
    February 23, 2006 at 11:42 pm
    I project DV footage all the time.
    SD is SD. And a clean DV can look VERY nice in an SD projection.
    (Heck, we used to project VHS, and THAT is LOW-rez!)
    OTOH, the kind of IMAGE you DESCRIBED will probably NOT look so good.
    Attempting to project a “very dark” image with “low lighting” will not hold up well.
    But you won’t KNOW until you try it.
    February 24, 2006 at 3:37 am
    As I was viewing a movie on my 7-foot projection screen, I thought I should add that “DV” is MUCH LESS COMPRESSED than “DVD”.
    And DVD’s are probably the “most-projected” format in SD today.
    Good DVDs look sensational when projected.
    But, as was said before, the fact that your project is DARK will be the biggest problem.
    LCD/DLP projectors have limited contrast (compared to direct-view screens) and “too dark” is not easy for them to handle.
  • Aanarav Sareen
    March 2, 2006 at 5:51 am
    Thanks for the info. We ran a test screening and it turned out to be OK. Nothing impressive, but we are going to try and color-correct some of the content, so that we can view it better.
    Aanarav
