Activity › Forums › Adobe After Effects › project wont open
  • project wont open
    Posted by Isabella Salerno on May 20, 2019 at 12:56 am
    im trying to open my project in after effects. it’s saying, ‘after effects warning: unable to import file ; on going as a project (bad format or not readable)’
    at this point i think its gone but its really important and i spent hours on it. is there any way for me to open it?
    Andy Engelkemier replied 7 years, 2 months ago 3 Members · 3 Replies
  • Kalleheikki Kannisto
    May 20, 2019 at 11:45 am
    Since the error message says “import” rather than open: Are you sure you’re trying to open an After Effects file?
    Senior Graphic Designer
  • Isabella Salerno
    July 24, 2019 at 3:24 am
    yes i tried opening it by double clicking on the project file and by opening ae and then file>open project. both ways say the same thing.
  • Andy Engelkemier
    July 26, 2019 at 2:26 pm
    well, don’t forget to try and Import the file as well. But it sounds a lot like you have yourself a corrupt file.
    Don’t forget that if you’ve rendered it out, there’s usually a copy in the AME folder.
    And you Should have Autoback turned on by default as well, also assuming this was your file to begin with.
    Just to see if you get Something, also try importing it into Premiere and/or AME. Sometimes one works and not the other.
