Activity Forums Adobe Encore DVD Project Window: “Blu Ray Transcode” Setting/Check Project Feature
  • Project Window: “Blu Ray Transcode” Setting/Check Project Feature
    Posted by Adam Schreck on November 24, 2010 at 5:56 pm
    There may be some newbie boners in my workflow/questions, please bear with me.
    I’m authoring a blu-ray DVD for consumer use. I edited in Premiere and exported my blu-ray assets as “Blu Ray MPEG 2.”
    In Encore, everything previews and plays correctly. On the build, I used the “Check Project” function before burning my first disc and it appeared to burn cleanly. However, when a friend tested it on a blu-ray player (about a year old), the player didn’t recognize it.
    Looking back over my project, I noticed a “Blu-Ray Transcode” setting in the Project menu. On the first build, it was set to “Don’t Transcode.” I’ve since changed that to “Automatic based on project settings” (Blu-Ray, MPEG 2, 1920×1080, FPS 29.97; 30.0 Mbps).
    My questions:
    –Should that take care of the player issue?
    –BoyGolly, I would think Encore would have thrown an error message during the burn, am I missing something with the software? (And, as I said, I am new to this workflow.)
    Thanks and Happy Thanksgiving!
    Daniel Ludwig replied 15 years, 9 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    November 29, 2010 at 5:33 am
    Hi Adam,
    there could be several issues, why the disk wouldn´t be played within the player!
    in general it should be played, but there is no transcoding-reason why it should NOT be played.
    I would suspect the player itself or maybe a bad optical media, if it wont be played in other player as well.
    please make sure, that you´ve got good media-typs like verbatim.
    some older player couldn´t play BD-R media, in that reason you should test the disk with other players as well.
    cheers
    danny
