Activity Forums Adobe After Effects Project will not render – Any ideas?????
  • Project will not render – Any ideas?????
    Posted by Toby Lakeman on August 13, 2011 at 10:56 pm
    I made animated a path and can not render it out.
    I have worked with after effects for years and never had a problem rendering out a job. I have animated a path and attached a screenshot. Tried a quicktime animation, h264 and an avi can’t get any picture. You can see the camera movement on the ground but no animated path.
    If I render in the project you can see the path animate but render out a file and nothing very strange. Restarted computer checked all settings to no avail. Im on a fairly new Mac only a year old.
    If anyone has any thought much appreciate a response.
    Toby Lakeman replied 15 years ago 2 Members · 2 Replies
  • Stefan Hinze
    August 14, 2011 at 1:24 pm
    (this goes more in the direction “did you turned on the computer”-hotline advice, but anyway)
    is the camera you animated, set as the one AE should use to render?
    is you footage set as a guide-layer?
    try to precompose the whole thing and then check if you see the right camera.
    greets
    steven
    (take a step back, to see the bigger picture)
  • Toby Lakeman
    August 14, 2011 at 10:56 pm
    Thank you it was set as a guide layer. I have not used these before but that was the problem cheers again.
