Activity Forums Adobe Premiere Pro project trim error
  • project trim error
    Posted by Rienws on March 15, 2006 at 10:00 am
    Hi Guys….
    When I in adobe premiere pro 7.0 a project trim I get this error:
    \dev\stingray\Backend\Src\Time\TimeTransform.cpp-77
    I need to trim my projects. Please can anyone help me?
    Rien
    Shane Chadder replied 20 years, 5 months ago 2 Members · 1 Reply
  • Shane Chadder
    March 17, 2006 at 2:24 am
    Trimmed projects crashes can be tough to troubleshoot. I find it most often relates to Premiere having trouble trimming certain codecs or files, and sometimes the larger the project the more finicky it seems to be.
    What I do is….
    1) Start the trim process as normal
    2) Open the folder the files are being written to and leave it open on top of Premiere.
    3) When premier chokes DON’T click on the OK. First write down the name of the file it last tried to write.
    4) Now click OK.
    5) Set that file it choked on as “offline” in the bin and restart the process.
    6) Once you get the trim to work manally copy the problem files over and relink them in the trimmed project.
    Right now in version 2.0 I find that if I use *.psd files as logos in titles a large project will choke during trimming. Small projects are ok.
