Activity Forums Maxon Cinema 4D project texture with light
  • project texture with light
    Posted by Frank Feijen on December 19, 2014 at 11:33 am
    I’m trying to project a texture (example: a logo) via a light onto my scene. So i have a negative light with a texturetag, with the file in the transparency-channel of said texture.
    The problem is that objects don’t block the light.
    If there are 2 cubes behind each other, the texture is visible on both cubes. Whilst the second cube shouldn’t receive the light since it’s blocked off by the first cube…
    Any clues?
    Brian Jones replied 11 years, 8 months ago 2 Members · 1 Reply
  • Brian Jones
    December 19, 2014 at 3:00 pm
    turn on shadows in the light or in the light’s Project tab put any objects you don’t want the logo on in the Exclude area
