Activity Forums Apple Final Cut Pro Legacy Project Stuck in Compressor
  • Project Stuck in Compressor
    Posted by Ronald Thomas on August 21, 2008 at 7:43 pm
    I’m trying to crunch a project with compressor but something happened and it seems to have gotten stuck. It won’t let me cancel it in the batch monitor – it just says “cancelling.” I’ve tried quitting (it lets me quit the application no problem) and restarting the computer. When I submit a new project the old one shows up in the batch monitor still trying to compress and it won’t compress anything else. I can’t seem to get rid of it. Anyone have any ideas here?
    FCP studio 2
    Mac G5 OSX 10.4.11 dual 1.8
    Ronald Thomas replied 18 years ago 3 Members · 4 Replies
  • Greg Ball
    August 21, 2008 at 9:34 pm
    I would trash your compressor preferences
  • Lisa Imbruglia
    August 25, 2008 at 4:20 am
    I am having the same problem. I really just want to get it to stop and clear all the back logs and start afresh. It seems to make no difference when I hit cancel. Getting really frustrated by this as need to convert from PAL to NTSC and the last time it took 34 hours. I need to finish this job.
    Lisa
    I have a G5 Dual 2ghz with 1gb ram. I have an ATI Radeon 9800 Pro card.
  • Lisa Imbruglia
    August 25, 2008 at 8:32 am
    I’ve just had the same problem and finally after much searching online with very little definite info I did a couple of things.
    Firstly I trashed the preferences for Compressor, Batch monitor and another one with compressor in the name. Then I restarted the computer resetting the pram (as soon as you push the on button press “apple, option, p, r”.) Allow the computer start up to sound 3 times.
    Then I went back to Compressor history and cancelled the jobs that I had inadvertantly lined up and they actually cancelled.
    Pay no attention to what is happening in the batch monitor as it will follow suit when the history side is sorted.
    I hope this helps anyone including yourself.
    You can let me know if this works for you.
    Cheers
    Lisa
    Mac 10.5.3 Dual 2ghz proc. 1gb ram.
  • Ronald Thomas
    August 25, 2008 at 9:25 pm
    I actually wound up having to reinstall. I tried trashing the prefs and all that and nothing worked. Ah well.
    RJ Thomas
