Activity › Forums › VEGAS Pro › Project sound level suggestions
  • Project sound level suggestions
    Posted by Jeff Mcguire on September 8, 2009 at 12:24 am
    Since wedding videos are lengthy and have such varied sound levels, I was curious as to how others approach setting Vegas Pro.
    Do you normally set the Master level higher and then bring the Gain down?
    Does it help to insert volume envelopes?
    Anyone using the Master track?
    Jeff
    Dave Brandt replied 17 years ago 2 Members · 3 Replies
  • Dave Brandt
    September 8, 2009 at 8:43 am
    Hi Jeff,
    Your dialog levels should be around -12db to match up with broadcast standards, I would not change the master level from the default 0db. The best way that I have found to level the volume on a project is to individually adjust each sound clip by dragging the volume bar on the clip itself. You will notice that this is usually set to default 0db, therefore you can only decrease the volume by pulling the clip level down. If you need to increase some clip levels to match the ones before and after, normalize them and then adjust the levels down to match. You can also use envelopes to adjust the volume, but in my experience I have found the method above to be easier to manage, especially when you are likely to fine trim events again later on. You can also use compressors and limiters to even out the volume on your track, but I would always start with adjusting the clips themselves first.
    As regards the master track, This is useful for adding Audio fades at certain points affecting all audio in the project using envelopes, for example between scenes where you may wish to lower music dialog and fx all together to transition to the next scene.
    Hope this helps
    Dave
  • Jeff Mcguire
    September 8, 2009 at 10:17 am
    Thanks Dave! Great advice!
    Regarding the Master track, couldn’t I use that to fade out all levels (tracks) of 5.1 surround sound?
    Jeff
  • Dave Brandt
    September 8, 2009 at 10:59 am
    Hi Jeff,
    Yes you can fade out whatever your project audio settings are, if that is surround sound then it will fade all channels
    db
